I recently adopted a dog on short notice, and can't afford traditional fencing. I looked into wireless invisible fences, but the layout of my property does not work well for a circular radius. So, my solution has been to go with traditional underground invisible fencing. However, it is winter here and the ground is frozen, though probably not more than 3-4 inches deep. I don't want to wait until spring, so I came here for help.
I am a complete newbie when it comes to DIY projects, so I have no idea where to start.
  • I tried just using a shovel to dig a small trench in the ground, but it was too difficult to get any depth and I don't favor the idea of doing that manually around the perimeter of my 75 x 50' yard.
  • I have a reciprocating saw; Can I use that to cut into the frozen ground?
How can I best install the underground wire for the invisible fence in frozen ground?
dpatchery
  • 133
First thing first, do NOT use a reciprocating saw for this as this is dangerous and you could end up seriously injured.
If looking for something to make this easy, what you need is a trencher - you can probably rent one from your local home improvement store. It will look something like this (there are smaller models but I couldn't find a good picture). If you can't rent one, maybe try contacting a sprinkler installer to see if they could come do it for you.
Trencher
EDIT: Found a smaller one, looks like this:
Small Trencher
(source: terrasaw.co.nz)
Alternatively, as others have mentioned, you could just lay it on top of the ground for the short-term. And of course, some back-breaking labor would also accomplish the job.
Glorfindel
  • 1,187
Steven
  • 27,770
  • 56
  • 90
