I've seen these kind of marks on several steel rods, usually axles, but I don't know how are they called and which tool makes them. They are usually used to stop something, like a washer, go past them. I may need to do a couple of them on a another rod.
Does someone know how are they called and how to do them? Thanks
blahdiblah
  • 127
bcasquinha
  • 81
If you are not making 10,000 rods per day, you don't do this, you stop the thing you are trying to stop by drilling a hole through the rod and inserting a pin, typically a cotter pin or hairpin. Or applying a stop-collar with a set-screw.
If you are making 10,000 rods per day, you put the correct die in a punch press, grab the safety paddles and hit the actuator.
If you have a unresolvable perceived need to make this sort of deformation at home, put the rod in your forge and the appropriate die-set in your hardie-hole. In your anvil, which, of course, you have along with the forge and a whole lot of hammers.
