Background: I have a 6yr old new construction home. A small deck (roughly 9x9 if you exclude the stair cut out) was built just to come out from the kitchen. The house has a garden view basement, because the house is built on a slope.
Objective: I'd like to extend the width of this deck about 16-17ft, and basically keep the old deck, minus the railing at the side I will be extending.
Currently the deck is connected to the house by a ledger board, and then the front uses slotted 6x6 posts to support the rim joist.
What would be the best way to extend the rim joist into the new deck? I haven't built a deck before, but I would like to tackle the job myself. I do plan on submitting a permit and plans next week to my city's building department.
I was tossing around some ideas: Should I put another 6x6 as close as possible and have the extending rim joist cantilever a foot or so to the old deck? Should I try and cut back the old rim joist to where I can seat the two (new and old) together on the original 6x6 post and extending from there? Or can I just somehow attach the extending rim joist to the end of the original deck (the band joist)?
Here is a picture of the original deck when it was first built to get an idea of what I'm working with.
Picture of current deck
eaglei22
  • 1,103
  • 44
It should be acceptable to cut back the existing rim joist and ledger to allow supporting one corner of the extension on the same post. assuming the post and footing are sufficient for the added load.
Jasen
  • 26,920
  • 46
