Someone on this stack had written the following as an answer to a question back in 2011. I have been trying to research this very subject. Where in the code does it state that an Electrician can be held liable for previous work violations?
Let's say your house is really old,and has some knob & tube wiring. Perfectly safe behind sealed interior walls UNTIL you try to load that circuit beyond 10 amps; then the knobs (which insulate joins and corners of wire runs) heat up, arc, and start fires. Now, the standard is insulated multi-conductor cable, with all wire joins located in fire-rated, accessible junction boxes. It is illegal, ANYWHERE, to simply wire-nut some modern 3-conductor insulated wire to the end of a knob & tube conduit and start using that; the entire run, all the way back to the panel, must be ripped out and replaced with modern 2- or 3-conductor wire in the proper gauge for the required load. Usually, when an electrician catches any hint of knob & tube in a house, he will insist that the entire house's wiring be brought up to code even if he isn't touching any knob & tube himself, because if he knows about it, doesn't do anything about it, and the house burns down, he can be held liable, lose his license and even go to jail even if it wasn't his work that failed.
Pete7
I don't ever remember seeing a liability issue stated in the code. That would be between your insurance company, the lawyers and the electrician. Anybody can sue anybody. The code simply states what must be done. If renovating a floor in a house with K&T, the K&T has to be replaced but it doesn't have to be replaced in the entire house under normal circumstances. I think most of us out there would warn the customer if there was a problem and note it on the invoice. I have, once or twice, notified the local inspectors when I came across extremely hazardous conditions.
  • 139,495
  • 149
  • 386
JACK
  • 89,902
  • 214
The code itself is not the enforcement arm but it sets the Minimum standard.
the AHJ (authority having jurisdiction) is the agency or building codes division of your state that inspects the work to verify the work was done to code. Failure to meet code can have financial impacts along with the loss of the license & bond that allows one to do the work.
If a shortcut was taken that violates code and later that shortcut ended up causing a loss of property or life the insurance companies are the driving force for legal action to recover some of the losses.
The person that preformed the work is the one they go after, the state is not held liable unless corruption can be proved.
There have even been suits when the work was completed to code but 12-15 years later the code changed and a loss happened that the suit tried to get $ for what was a legal installation at the time.
So to answer the question code is the minimum standard. State and local administrative rules and law may have penalties for violations but normally it is the legal system that goes after the license holder for the work done.
Ed Beal
  • 103,727
  • 79
  • 158
