I have just moved into an old apartment in Brooklyn. The landlord has warned us that all the walls are plaster with wood framing. I have not dealt with this type of wall before. I would like to hang pictures (both small and large) as well as a fold away table that would weigh about 40 lbs. I have heard Plaster walls crack easily.
The Table top will be a modified version of an Ikea Vika table. I will be adding swing out legs, so as to support it when it is in the folded out position.
What considerations do I need to make with mounting these things to the walls, so to avoid cracked plaster, as well as the walls falling down?
Your task is to find the studs..
Electronic versions of stud finders abound, plaster is difficult for most of them. I have a 1/2 dozen of them.. I keep hoping. The problem with plaster is the lath used to support it. The lath can be a variety of materials: wood strips, metal mesh and even pasterboard. All of these materials are attached to the studs and THEN the plaster is coated over the lath. Two newer scanners aimed at professional use Milwalkee scanner Bosch scanner . They both will detect electrical wires and some pipe, but you are on your own for proper interpretation.
One technique is to verify stud location is via drilling a short depth (not more than an inch to verify a stud)
Drilling in plaster: masonry bits or ceramic tile bits are the best to use to cut through the plaster with fewer cracks. Driving nails is a plea for cracks. The drill diameter should match the screw diameter, to not place stress on the plaster. The actual screw holding will be done by the stud.
Once a stud is located, wood screws should be imbedded 1/2" or more, depending on the weight. The earlier comment regarding a "buffer" board spanning the area is a good one, especially if the place you want to attach is between studs.
Finally, patching small cracks is not hard, use Durabond setting joint compound to mimic plaster.
HerrBag
  • 12,225
  • 37
