Our house (built 1953) has galvanized piping for the cold and copper for the hot water supply lines. We had good water pressure (85 psi), but low flow (2.5 gpm).
I had a plumber replace the galvanized main water supply from the city water meter to the front spigot with 1.25 inch PEX. He also installed a PRV set wide open (80 psi).
At the front and back of the house, we are now getting 3 GPM. Unfortunately, when the outdoor hoses are on, the indoor water flow goes to a trickle.
The plumber says I should be able to get at least 6-11 GPM at the front spigot, but it is not happening. He assures me that the pipe from the water meter and our shutoff valve are clean. While I would love to get rid of the galvanized pipe under the house, it is not worth it until we can fix the flow to the front spigot.
Is there anything else that we can do? Is it possible there is something wrong with the city water supply, or the meter itself?
Juan
  • 101
0 Answers0
