thanks for reading this and offering your advice.
So first I changed the switch which was super easy and the kitchen light continued to turn on and off totally fine. Then I went to change a nearby outlet (I say this, because obviously these are connected in some way behind the walls), which again seemed pretty straightforward with the classic set up of two black wires, two white wires, and a ground. Again, process went smoothly and the outlet works (both upper and lower). BUT now the darn light won't turn on! I've been trying to figure out why, or what to do next to try and troubleshoot, and I've read some things about breaking the brass tab on the outlet. Does anyone think, or know, if this is the solution? Or should I try something else?
Just seems odd to me that the outlet would work but the switch (again, presumably down the line of connections) wouldn't. I would think if they both didn't work, I would just need to recheck all of my wiring connections.
Also, nothing tripped during or after this installation process. And I did turn off and on the main switch from the power box several times, in an attempt to "reset" something?
HELP!
Holly
0 Answers0
