I have a bathroom sink that gets clogged (or the water goes down very slowly) about every 2 to 3 months.
When it gets that way, I put some Drano down and it solves the problem. My concern is that the Drano will do real damage to my pipes over time.
brhans
  • 7,241
  • 42
Bob
  • 425
Drain cleaner is mostly sodium hydroxyde (caustic soda), that's fine for your pipes. It dissolves fat and organic material, including eyes and skin, so make sure to wear safety glasses and gloves. The child-proof cap on the bottle usually requires a lot of force to open, and when you do that, if you're squeezing the bottle while fighting with the cap and it pops off, it could squirt straight into your face.
I've seen some people use acid instead, that's a very bad idea, it's just as dangerous, stinks more, corrodes some common materials like cast iron, concrete, tile grout, removes chrome plating from faucets, oxidizes copper and turns it green...
Resistance to sodium/potassium hydroxide:
In fact, besides the user, the most likely victim of alkali drain cleaner would be anodized aluminium. Caustic soda both removes the anodization and corrodes aluminium. No-one is using aluminium drain pipes, but there could be cosmetic damage to nearby objects like door handles or tile trim if it splashes on them.
bobflux
  • 11,121
  • 35
According to most sites drano is not kind to plumbing, it does eat away at clogs fast, but those chemicals also touch your pipes. Using it once every few years might not do much, but every two three months is not good.
Clogs can be caused by putting stuff down the drains that collect, bad drain design(not enough slope/used of flexible pipes with ridges). Minimum slope is 1/4 inch per foot, more is better, for horizontal pipes.
For removing clogs a snake is much safer.
Should run or have a plumber run a camera down the pipes to see if anything is in there for clogs to catch on.
Plumbing system might need slope adjust so water(plus stuff) can flow more easily to main drain/sewer.
crip659
  • 32,986
  • 39
  • 85
Mechanical cleaning (no Drano)
Open the P-trap under the sink.
It is only hand tied nuts, no tools needed.
It does contains about 1/2 gallon of water so have a pan to catch it.
Now you can clean the p-trap, the sink drain and part of the pipe going in the wall. That is usually where most stuff is.
You can also use a plastic snake to poke in the drain with ease, since you removed the p-trap.
Preventive measure is to have small holes sink drain cover, to catch the hair before it goes don the drain.
I do not know the Drano corrosive impact on pipes, but it does attack the metal.
DIY75
  • 20,686
  • 47
