I want to close a rectangular vertically mounted pipe with a piece of flat PVC plastic. I will use the pipe for growing herbs on the wall outside my house, so it needs to be non-toxic.
I was thinking of using glue or cement for that. Does anyone know any non-toxic glue or cement to do the job?
Or maybe someone have a mechanical idea without using glue?
  • 20,909
  • 95
  • 135
Juila
  • 65
Gorilla glue makes a non-toxic PVC cement.
Bryce
  • 11,057
  • 77
  • 120
shirlock homes
  • 58,628
  • 87
  • 168
You should replace PVC by other material like PP or HDPE, PE, glass, wood...
Pure PVC is non toxic, but normal PVC can contain toxic chemical to increase lifetime, reduce cost making...
PVC, uPVC water pipe is food safe but it's usually contain heavy metal that can go out when under heat, pressure and long time using.
Even food safe PVC under sunlight (contain Ultra Violet Ray) will be oxidized and release toxic chemical.
For PP, HDPE, PE You can use solder welding and adjust to the right temperature to join without glue
Glass, ceramic glue: 100ml cow milk + 100ml vinegar and then blend well. In other cup, we fill 2ml water and put in ½ egg-white then blend it. And then pooling the water egg-white solution into the milk cup, blend and add 2g lime and blend. Using this glue by apply on surface, then join and fixing, wait until the glue nearly dry and heat it on flame. Done when the glue dried.
Wood: milk glue, nail
phnghue
  • 101
Purchase the PVC cement for potable water plumbing. Ask a salesperson in the plumbing department. Given the hub-bub above, one does need to use PVC pipes rated for potable water, i.e. Schedule 40. You might find PEX easier to work with.
PVC pipe is not inherently safe for drinking water, even before you cement it. See http://chej.org/2013/09/pvc-pipes-bringing-toxic-lead-to-drinking-water/ and http://water.epa.gov/drink/contaminants/basicinformation/vinyl-chloride.cfm
PVC pipes can leach both lead and vinyl chloride. CPVC pipe adds chlorine (another toxic) to the mix, compared to regular PVC. PVC contaminates other plastics if mixed in during recycling.
All plumbing materials leach something into the water: do your research. The glue is likely not the biggest concern after installation.
Bryce
  • 11,057
  • 77
  • 120
