With a storm bearing down on the mid-Atlantic US and robocalls from the local power utility warning of the possibility of extended power outages, I figured tonight would be a good time to check the status of my 5700W portable generator. After turning the fuel valve to 'on' and engaging the choke, I pulled the pulled the starting cord, and pulled, and pulled. No luck.
The generator is fairly new -- I bought it at the end of June '12. I last started it a few months ago -- around November I think -- and since then it's been sitting in a dry shed with half a tank of treated gas and the gas cap closed tightly. The gas appears to be okay -- it's not cloudy, doesn't look separated. I get a whiff of gasoline after a few pulls, so I think there's some fuel flowing. The spark plug wire seemed firmly seated, but I pulled it and reseated it just to make sure.
What else should I be looking at to get this small engine started?
Caleb
  • 875
I would replace the spark plug and remove the air filter to make sure it isn't plugged up. Then, while the air filter is still removed, spray a little starting fluid into the carb through the hole under the air filter and start it up. If it runs for just a couple seconds and dies, that means the gas in your carb was probably bad. Starting it with the starting fluid a couple of times will work that out, and it should start running fine. Keep your face and other body parts away from the hole you spray the starting fluid into so you don't get burned by a backfire. Put the air filter back on after you get it running.
Other common fixes are pinched or clogged fuel lines or a clogged fuel filter, but if you're smelling gas, that probably isn't the problem.
You should also check that the spark arrester in the exhaust pipe isn't clogged up with carbon. Undo small bolt adjacent to exhaust pipe and remove insert. All small holes should be clear.
Daniel Griscom
  • 6,319
  • 43
Paul
  • 931
  1. Pulling the plug is quick, easy check if you have the right socket. Should be fairly clean, with a gap.
  2. BTW, my Gen has a separate on/off switch, yours?
  3. Next up would be some carb cleaner (after pulling air cleaner)
  4. Remove and clean carb bowl, float and orifice.
  5. Would also drain gas, put in car day after fillup, refill with new gas and treatment
  6. Next time, shutoff petcock below tank while running and run gas out of carb. Takes a bit longer to restart, but guarantees no gum inside carb.
HerrBag
  • 12,225
  • 37
No one mentioned running out of oil. Our generator ran out of oil and totally stopped. When new oil was put in the generator started right up again.
  • 20,909
  • 95
  • 135
