-1
There is a cupboard in a bathroom that appears to have some strange smell coming from behind the wall.
We've checked the sink to see if its leaking and there is no sign of that, have cleaned through the drainage pipes underneath and are now left to look behind the wall.
How is the best way to cut though the wall so that I minimise damanage and are able to repair the area behind the cabinet afterwards?
Or is there an easier way?
user1605665
  • 189
This is definitely a question for an electrician. ;-)
Get a single-gang or two-gang old work low voltage bracket. (photos: homedepot.com)
1-gang bracket 2-gang bracket
Cut a hole in the back of the cabinet to accommodate the low voltage bracket. Use a jig saw, hand saw, oscillating multi-tool, reciprocating saw.. whatever you have available with a suitable blade. Before cutting, make some effort to estimate the location of the wall studs and then position your hole so it won't overlap a wall stud.
When you've finished having a look inside the wall, install the bracket and a blank cover plate. Finished! (photo: lowes.com)
cover plate
Greg Hill
  • 35,866
  • 42
  • 91
