I made a table using MDF, but since it had more height than it should I had the unfortunate idea to cut it at home using a Jigsaw tool. When I used it the cut was not completely straight as we can see in the image.
Table mdf
What I want to do know is to find some solution that repairs or remediates this irregularity, because right know I'm using woods parts to help.
Nmaster88
  • 121
A straight edge clamped on so the blade just touches the high spot and trim the rest off.
Screw on some trim wood to cover and straighten.
crip659
  • 32,986
  • 39
  • 85
Well, you could get a better fence and use a circular saw to level the whole thing off. You could get some 1" x 3" trim board and make a frame that fits around the bottom. but the table into the frame, level it and screw the frame to the table. Paint the same color and it will look like it was designed that way.
JACK
  • 89,902
  • 214
While it won't make it look perfect, you can make the table top level using leveling feet:
Leveling feet
This example is from Amazon, but similar (if not identical) items are available at hardware and big box stores. There are many types - some mount to side/bottom like this one. Some are designed to be screwed vertically into the vertical pieces - that only works if the vertical pieces are relatively thick.
  • 139,495
  • 149
  • 386
