About a month ago my apartment shifted slightly on it’s foundation and caused a bunch of issues, one is that the tub overflow pipe is off-center now and the plate completely fell off. (I realize the foundation is a much bigger problem but I rent and nothing can be done for that unfortunately).
Is there any kind of temporary fix I can put in place to at least get the tub plate back on? The screw is off-center about an inch and I tried nudging the pipe back but it doesn’t move.
My landlord doesn’t want to fix it because he said he’s just going to redo the bathroom after I leave, but I’m also not allowed to drill or hire anybody else so my DIY options are kind of limited. But I’m learning to become handy and decent at cobbling together fixes and I’m hoping there’s something I can do. I know it’s silly but I just hate that it’s like this, it looks awful. Thank you in advance for any help.
Katie
The easiest way would be to get a small tube of silicon caulking/gasket maker. Clear will look nicest.
Clean around the hole and the drain cover. Remove the screw. Place the silicon around the edge of the cover and press onto the hole. Might want some tape(duct) to hold the cover on, till the caulking dries. Do the same with the screw and push it into the cover hole.
Spread some of the caulking around the cracks in the tub.
Any leaks, blame the landlord for not fixing. Would try to have to not need the overflow. This repair is just for looks.
crip659
  • 32,986
  • 39
  • 85
