Several of the tabs on my sheds "skylight" have broken off and now the roof leaks. What can I use to cover this area and stop the leaking?
If it's something like this removing skylight from resin storage shed then I would suggest simply putting on some disposable gloves or using a popsicle stick and smearing a liberal amount of Silicone Caulk (clear or colored) in and around the tabs or their previous areas.
A few coats or applications would be very good for a decade. If there are rather large holes or gaps, then just use duct tape as a backer from the inside to start with. After a day or two you can trim the tape overhang down and smear the backside a few times for a solid patch.
Iggy
  • 10,392
