I don't know what the proper name of the cover is that hides the hole that the water supply line comes through the wall, but does it need to be sealed to prevent moisture and steam from getting in to the wall? If so, what material should be used? Plumber's putty, caulk, silicone?
Chris Cudmore
  • 14,169
  • 61
  • 91
Evil Elf
  • 4,414
  • 54
  • 65
I have personally never sealed or caulked the shower neck cover and haven't had any real moisture problems as a result.
The plate is mostly meant to be aesthetic rather than functional, to hide the ugly hole in your wall that your shower neck extends from. Moisture shouldn't be a problem unless their was negative pressure inside of your wall as compared to the bathroom. This of course shouldn't happen because you should have a fan going while you shower, and this fan will create a negative pressure in the bathroom vs. the inside of your wall. When the fan is running, air will actually move from the inside of the wall into the bathroom.
If it really concerns you then you can use a bit of paint around the edge to form a seal, but I don't think it is necessary.
maple_shaft
  • 3,231
  • 35
  • 49
In an apartment building, we usually put a non-siliconized kitchen and bath caulk around it to restrict pests that like to travel behind the walls. It’s easy to remove when repairs are needed. We also do around faucet handles, toilet line, and any other access point to wall voids.
Moisture plays no roll in that decision, however.
Amazon Dies In Darkness
  • 2,749
  • 45
  • 70
