I’m replacing an outlet on a 20 amp circuit with a GFCI, and I noticed the wiring is 14 gauge. This is in a house built in 1964. I know this generally isn’t safe and have read a few other questions on the topic (e.g., 14g wire on 20amp circuits all over home My 20 amp circuit has some 14 gauge wire in it. Is that OK?). But I still have a couple questions.
One, in of those threads, a commenter mentioned “it would take more than 15 amps plugged into the duplex outlet at the end of the circuit to overload the wire” — does that mean I can address the issue by putting in a 15A receptacle instead of 20A? (FWIW, the old receptacle was 15A.)
Two, in this random forum thread I found, someone commented “It could be permissible to have conductors with a lower ampacity than the OCPD if the circuit were feeding AC units or motor loads.” Could someone unpack that for me? There’s a washer and dryer on this same circuit — since those have motors, are they “motor loads” and is it OK for them to be on a 20A circuit with 14 gauge wiring?
zephryl
  • 105
0 Answers0
