What considerations are important to take into account when planning a non-load bearing stud / partition wall that will run in parallel to both ceiling and floor joists?
The stud wall will have a sliding door. The length of the wall will be 3m.
The ceiling joists are timber and the floor is concrete.
Can the stud wall be positioned between floor joists and between ceiling joists or does additional support framing need adding.
What framing needs adding in that case. While ceiling can be potentially lifted to install additional blocks between joists, it would be difficult. Is there an alternative?
And what about concrete subfloor? Is there anything required or can the stud wall simply sit in between joists?
Thank you very much in advance for all answers.
