Weird question I guess, but I’m second guessing my handiwork.
I’m a DIYer, watched a bunch of youtube. For two separate projects I soldered 16 joints and 6 joints. (1/2” and 3/4” copper) For both when I turned the water on nothing leaked… so quite obviously I have done something wrong.
So my question is: If it’s holding now, when is it going to fail on me?! Thanks!!
I reemed, and wire brushed all joints both inside and out, thin layer of flux on pipe and fitting and then heated from the bottom. Then applied 1/2” or 3/4” of solder (depending on joint size) - basically until I saw a drop at the bottom of the joint. Then waited a few minutes and wiped them down and inspected to see if I could see a little solder in the joint all the way around.
jsharpe
  • 129
You are joking about your abilities. Confidence comes with experience.
If the joints were going to fail they would have shown leaks within seconds of you turning the water back on.
RMDman
  • 52,615
  • 113
