I have two circuits in my garage. One is a 15amp circuit that powers the garage door and has two outlets, the other is a dedicated 20amp fridge outlet. Both have GFCIs. I'm trying to run a kiln in the garage and it keeps tripping the GFCI. What's weird is that it keeps doing different things.
For context, the machine needs to be run for 14+ hours straight overnight when in use. I was able to achieve this cycle once, but the next time I tried it tripped the GFCI sometime in the night. After then, the kiln would trip the GFCI almost instantly when the kiln's heating element was turned on. The kiln seemed to be fine when turned on but not actively heating.
A couple days later I tried it again, and after 2 hours or so of heating, the GFCI had not tripped. Thinking the issue had somehow resolved itself, I did another night cycle only to find it had tripped sometime during the night. I am almost certain the furnace does not trip on normal circuits.
Relocating the kiln is out of the question. Obviously I can't have a kiln inside my home and the outside outlets all have GFCI as well.
I really wish to get this kiln working again soon so I've been debating bypassing or installing a regular outlet, although doing so does scare me a little bit. I'm just not sure what the issue can be here.
