Have just bought a house in which we've inherited a hydronic system - so just beginning diagnosis and diagramming, etc.
It seems that radiators use only one line for both supply and return; presumably valves in each radiator regulate flow to that radiator? Apart for a need for balancing the whole system - some rooms are too hot, others cold - it basically works.
Longer-term vision for system is to break it up into 'n' zones; individual valves, and I imagine, dedicated return line. At this point, house has only two zones, so much work to be done in warm weather!
Does this sound like a crazy setup? An ad-hoc kind of installation?
DrLou
  • 113
You have a One Pipe System and it looks and works like this
one pipe heating
one pipe
Suggest to Read the article, it nicely explains the details.
The main drawback is there is a temperature drop at each radiator feeding back in the single line thus reducing overall heat supply. Thankfully each radiator has a thermostatic valve for individual control.
DIY75
  • 20,686
  • 47
