I'm building out a small public makerspace and would like to add a ventilated painting and staining booth. I'm expecting the size to be about 12 cubic feet (4' x 3' x 1'). There will not be spray guns, only stains and regular spray paint. The average surface area painted will be less than a sheet of paper, often less than a golf ball.
The opening will be about 3' x 1'.
I've read that one is supposed to have:
"100 CFM per linear foot of hood width for spray painting operations"
This is re-iterated in this question: How many CFM for a range hood do I REALLY need?
This seems excessive for the usage I'm planning. Every other resource I found on calculating CFM was focused on much larger projects with the intention of spraying (or cooking) constantly.
How can I figure out the CFM needed for something like this? Around what range should I expect?
EDIT: Most pop-up spray booths on Amazon are showing ~110 CFM in their specs https://www.amazon.com/s?k=spray%2Bbooth
Library Seph
  • 119
Too much air flow is not good for spray paint
Recommend to get fan speed controller
Since it is not possible to predict the correct airflow for spray painting. You definitely do not want windy conditions
DIY75
  • 20,686
  • 47
