12
I'm closing a new construction residential build. The builder did not include any documentation on how the wiring was done. My question to the community is two-fold.
  • First, should I ask for some documentation on how the electrical wiring is done?
  • Second part, if so then what exactly should I ask for?
I've found references online to things called Wiring Plans/diagrams and schematics but I want to make sure that I use proper vernacular when I bring it up. Ideally, this would be something I could show to any future electrician to give them a good idea of how things are done in case I ask to have something added.
Machavity
  • 26,498
  • 44
  • 100
rStrunk
  • 223
I tried keeping such documentation. But it isn't that helpful, and it goes out of date too quickly.
Code requires that all electrical connections be made inside junction boxes, and all junction boxes remain accessible forever.
That means that your entire house's electrical system contains only 2 things: a) junction boxes which are accessible, and b) cables or conduits connecting junction boxes which have no joins or splices in them.
This creates a world where wiring is largely "self-documenting" - one needs to simply look at where the wiring is likely to go, and open up junction boxes in that vicinity. This reveals everything that there is to see. Assuming rules were not violated. Circuits can be ascertained by shutting off a breaker and seeing what goes dead, and there are more sophisticated pro tools to trace any given cable leaving a box, but they're usually not necessary. An experienced person can usually just tell by recognizing the connection patterns given the usage.
Also, the most important documentation method is how the wiring is hooked up presently. About twice a year, a novice opens up a complicated box, unhooks every single wire from whichever terminal or wire nut it is on, splays out all the individual wires and takes a photo and posts it here. "How do I hook this up?" they ask. Well, we can't tell them because they just destroyed all the clues! So yeah - take great heed for how it is connected.
12
I would not expect any detailed schematic or wiring diagram, for a bunch of reasons. But what I would expect is that the breaker panel be clearly labeled, which is normally done prior to the electrical inspection by the city/county/state. If it is reasonably labeled then you will know which circuits control all large (240V) devices (oven, cooktop, dryer, water heater, HVAC, etc.), all major hardwired appliances (e.g., dishwasher, disposal) and the following 120V circuits:
  • Laundry Room
  • Kitchen Receptacles
  • Bathroom Receptacles
The remaining challenge will be to figure out which "general purpose" breakers control receptacles and/or lighting fixtures. Ideally they should provide a complete diagram, but as far as I know there is no obligation to do so.
  • 139,495
  • 149
  • 386
Wiring diagrams would be extremely unusual in a single domestic build
As would plumbing diagrams. Or HVAC diagrams.
I’ve been a building services engineer for over 30 years and I’ve only ever encountered electrical diagrams for a house once - the cost of the electrical build was AUD1.3 million (USD 870k). In a regular home, the electrical systems are just not that complicated.
Dale M
  • 380
The electrical layout on a set of blueprints simply indicate where the location of devices are. They tell the electricians and their helpers where to place the breaker panel and things like switch and outlet boxes and such.
You can easily see these things in your home. How the cables are run to the devices for termination are not indicated. this is done by the electrical crew according to the code in place at the time.
Therefore the electrical layout page is useless to you and a complete schematic does not exist.
RMDman
  • 52,615
  • 113
