I am planning to change the radiator in the bathroom for a heated towel rail, but before I do, I want to be sure of the air bleeding procedure as I am only used to central heating in 2 storey homes.
The process is normally easy to understand when you know how. As air rises in the system, in a 2 or more storey building, you work from the top floor to the bottom, bleeding the air out.
We moved a few years ago into a bungalow and the pipework leaves the boiler, goes into the loft, and drops down to a radiator, through the wall to another radiator in an adjoining room and then back up into the loft to go to another radiator in the same way.
I cannot find any bleed valves in the loft, so how do I bleed above the level of the radiators?
Chris Rogers
  • 443
Bleed at the highest point.
If there are no bleed valves at that point then fit them, which if you are planning the other changes should not be an issue.
Solar Mike
  • 30,038
  • 69
You can force air out of a system even without bleeders at the upper location.
Bleeders are good for small amounts of air.
The general way to get bulk air out of a system is to leave the pressure into the system open, close the return to boiler pathway and open the drain on the return. New water will be pushed into the system forcing old water and air to go out the return drain. No new air will be introduced to the system as your water in feed won't have any air in it.
You can still have small amounts of air in the system that take a while to work out so bleeders at the top locations are still a good idea.
Fresh Codemonger
  • 14,459
  • 57
Without bleed valves any higher than the radiators themselves, you can't. While the system is being changed, it's best to fit one, or two bleed valve in the loft, at the pipework's highest point. Problem solved for a very long time!
Tim
  • 5,501
You can usually get the air down into the radiators. Once there, it will rise to the top of each radiator, and get trapped where you can bleed it.
To assist the process, you can (a) turn the pump up the max, and (b) close off most of the radiators in rotation, to maximize the flow in other sections.
You are not working against the whole head of water in any pipe. If you can get some flow going, it will break up air pockets gradually and smaller bubbles will get dragged downwards into radiators quite happily. When it stops making gurgling noises, you have sorted it.
Paul_Pedant
  • 288
