During a remodel the contractor installed tile in a large shower. Next was to install the sliding shower door. The contractor tried drilling into some scrap tile and it broke/cracked the tile. So he refused to try to install the shower door. I think he didn't want to take on the liability of cracking the tile. So... now my questions are:
  1. do I try to get another contractor with more expertise?
  2. try to DIY?
    • If DIY what would be the best approach?
    • Maybe small drill followed by slightly larger and larger drills?
    • Or the third option I think would be to simply silicone it in place.
Any advice is greatly appreciated.
George Anderson
  • 23,304
  • 83
Simple rule: The harder the material is the more teeth is needed to prevent cracking.
Any drill with two cutting surfaces is not good for tiles. Use a diamond drill. Don't apply pressure and use plenty of water as coolant and lubricant.
DIY75
  • 20,686
  • 47
