To preface, some of the wiring in the family home was done "creatively" but it is only about 30 years old. I have previously replaced outlets and discovered the master bathroom outlets, one GFCI and one regular outlet, were not functioning. I don't know how long they were not working, probably quite a while.
I replaced the GFCI first and was careful about the load and line terminals and wires, and attached the grounding wire attached to the previous GFCI. Because I am paranoid, I turned the whole house electricity off, and as soon as I turned power back on, one breaker switch tripped right away. It didn't even stay on long enough for me to determine any fault with the GFCI itself, my helper said the GFCI light very briefly flashed red but it was not the same as any of the error codes on the GFCI packaging/instructions. The breaker switch that is tripping is labeled "Family Room 2" and as far as I can tell, all other lights and outlets are functioning besides the two master bath outlets, master bath fan and lights all work still. There actually is a "Master Bathroom GFCI" and "Master Bedroom & Bathroom Outlets" labeled breaker switches but I have no clue if those are properly labeled.
Did I mix up the load and line wires somehow? Should I try replacing the regular outlet to see what happens? I just want to do all I can safely do before I call an electrician.
