One of the 'quirks' of local public housing is that it comes with an 'ensuite' bomb shelter - basically a room of reinforced concrete with a pair of ventilation holes. I should be able to get plug in/mains power and I know there are companies that fitted in exhaust fans to these.
TLDR: I'm trying to figure out if I can swap the fragmentation plates for the ventilation for my household bomb shelter for ventillation fans
I don't want to make substantial irreversable changes.
I'm still waiting on the keys though I have a plan of the unit, and a rough idea of where sockets and such
I have a pair of air conditioning units that blow air into the living room and ideally I'd like things set up to intake air at one vent and extake at the other
The blue arrows represent the air conditioning units, and the two red arrows where the ventilation holes would be.
I've also got the specifications for the ventilation sleeves (and the bomb shelters)
Two 125 mm diameter ventilation sleeves shall be cast into the wall/s of each HS.
Each ventilation sleeve shall have a 6 mm thick stainless steel fragmentation plate mounted on the external face using 8 mm stainless steel bolts. See FIGURE 4.4(a) and (b).
taken from the 2017 edition of Technical Requirements for Household Shelters but there's a 2023 edition as well.
Usefully it has engineering drawings as well.
Practically they look like this
I can't find much reference to the 'inside' - I think this youtuber's shelter's a smaller version but that's what it is like on the inside. Here's another example - he has a portable air conditioner but ideally I'd like to avoid that. Does seem to indicate a 'standard ventsize though.
I need to be able to reinstate the 'original' plates and bolt, so the ideal would be something that'll 'just' bolt in, or need minimal modifications instead of the plate and intake/exhaust air. I've nearby sockets so something I can wire up to mains would be ideal.
This is both for 'legal' reasons (as per the specs) and if it doesn't work out I can just reinstate the original set up and pretend nothing happened.
What should I be looking at specifications/design wise to do this?
