These are usually proprietary, so you'd need to find one from the OEM or one that claims to be compatible, or you'd need to match some key attributes...
Most doors are 1-3/4" thick and either 32" or 36" wide, so you're mostly concerned with:
- Mounting rib spacing (they fit into the slots you see on the end)
- Bead or strip height (the space between the door itself and the threshold)
- Bead or strip location, as in where it engages with the threshold (probably less critical)
If you can match those up you're probably ok, though if you don't have an adjustable threshold your margin of error is small.
Helpful hint: Prolong the life of the new sweep by lubricating the threshold surface with something like silicone or Teflon. The high friction between rubber and wood can really tear things up.
If all that fails, you can probably find a nail-on one. Your door has a wooden core, so you can attach about anything that fits. Or use a draft stopper. Maybe you have an aunt who can knit you one.
