I've been having some minor trouble with my ac. When it gets hotter, towards the afternoon, it will lose ground and only be able to cool two degrees higher than what the ac is set to. For example, if it is set to 76, the thermostat will read 78. While it's not unbearable or super uncomfortable, it is a little bit noticeable. It didn't have any trouble the day before maintaining the set temperature, but today it was higher, despite the outside temperature being about the same.
I have changed my filter, put new batteries in the thermostat, made sure the heat pump is clean and free of debris and cleared away any grass or anything.
I would like to fix this but I wanted to ask for advice on my 3 ideas on what to do. Should I...
Replace the thermostat? My partner had trouble with theirs in the winter (it was running all the time) and replacing the thermostat helped there. I was wondering if doing the same would help me.
Call out an ac repair person?
Understand that it is hot and over 90 degrees and this is just how it is and suck it up? (I understand that heat pumps can realistically only cool about 20 degrees and may struggle with the new higher temps in the Summer)
I really appreciate your time and advice.
Thank you
