At night during the summer, we run the kids room mini split with the door closed, and I've noticed the humidity gets really high (measured at > 70%). This surprised me, as I assumed the AC would be removing moisture from the air - maybe not so much as to lower the relative humidity, but ideally not so little the the humidity increases substantially as the air cools. To check if the mini-split is actually removing any moisture from the air, I put a bucket under the drain line outside, and discovered that very little moisture is being removed.
I think the issue is that the unit is too large for the room (with the door closed). Here is what I think is happening:
- The unit turns on, cooling the room, and condensing some moisture on the coil.
- The room quickly reaches temperature. Very little of the water that condensed on the coil has made it to the drip pan. The compressor turns off, but the fan keeps running.
- The water evaporates off the coil and back into the room. The evaporation is exacerbated by the continuously running fan.
- Eventually, the temperature rises. Repeat 1-3.
One solution would be to open the door. Another would be to get a dehumidifier. Let's assume that those aren't acceptable solutions. Instead, I would like to see if I can get the mini-split to remove more moisture from the room.
My thought then is to cover some substantial portion (maybe half) of the coil on the mini split head so that 1) the unit has to run longer in order to cool the room, and 2) more water is condensing on a smaller surface area. I reason that both of these should increase the amount of water that reaches the drip pan and exits the house.
What are the main risks here? Or is there some reason this definitely won't work?
Edit:
- The unit is a Mitsubishi MSZ-FH09NA
- I am fine using more power to pull out the moisture. I assume that this will necessarily be the case.
- I don't know if this model is capable of multi-speed operation. At least I haven't seen any mention of this type of user-programmable setting in the manual.
- The unit does have a dry/dehumidify mode, in which the compressor runs continuously under low fan speed. It works great for dehumidifying. The problem is the unit does not have a humidity set point, so running in this mode all night would make the room unacceptably cold. (as an aside, if anyone is aware of a system that has either a) built-in hygrometer and dry mode with a set point, or b) even better, a dry/cool mode with simultaneous humidity/temperature set points, I would really love to look into such a product.
- There's lots of good discussion around my hypothesized underlying cause in How to I eliminate the smell coming from my Mitsubishi mini split units?, though the focus is on the associated smell.
