I am completely renovating a 2 bedroom home, where the two bedrooms are wired together on a single 15amp breaker.
I spent most of the day yesterday painting one bedroom while running a portable AC on max setting in the other bedroom. After I finished painting, I began replacing the electrical components when I observed the following:
- The receptacle was noticeably warm to the touch (presumably from my 11amp AC running all day on the 15 amp line)
- ALL of the outlets and switches appeared noticably "blackened" or burnt. Here is a picture of one of the outlets. Ignore the right side that was painted white - I painted over it since I knew I was replacing it. You can see what looks like the original color inside the left prong socket
- Some of the insulation of the neutral wires also appear blackened:
Is there something fishy going on with this room that I should be worried about, or is it just the case of some really old outlets going bad? None of the other outlets in the home look like the one pictured above, and presumably they were all installed at the same time.
