Should I sand the existing paint on my drywall before a re-paint? If yes, what sanding paper grit should I use? Thank you!
Asked
Active
Viewed 1,389 times
The answer depends on what the finish is that the current paint has. It also assumes that the new paint is compatible to the purpose. ( you are not using automotive paint on a wall of your home. Forgive me if I am too assumptive. People will do very odd things.)
If the current finish has a sheen that is flat, eggshell, or matt finish then no sanding is needed.
If the finish is gloss or perhaps even semi-gloss then a light scuff may be in order. For those type of finishes I just use a scuffing pad . I use fine or very fine. Then wipe the wall down with a damp towel.
You are then ready to paint.
RMDman
- 52,615
- 3
- 36
- 113
