I am installing three 81” shelves on a wall in a laundry alcove off a kitchen. The house is 100+ years old with lathe and plaster walls, orange peel surface.
Studs are located at 18, 34, 50, and 65 inches from right end (inside) to left (outside wall) but not at corners. One end is solid wood flanking interior doorway, the other lathe/plaster flanking window frame.
The shelves are 7-1/4” wide of select 3/4” pine. I have steel 1/4” thick L brackets at 5.25”, four brackets per shelf into studs, rated at 400 lbs per (presumably) pair.
I plan on a cleat along ends and wall, 1x2 (3/4 x 1 1/2”). Cleat will be notched so that the screw for the bracket will also support the cleat.
Will the cleat be enough to support the overhang of 15” and 18” (respectively) on either end?
