When I turn my plumbing tap on , it gives some whistle sound and I always get the sound , every single time.
Please find AV clip here.
None of the water taps give this whistle sound , how can I get rid of this noise.
Should I be worried ? Should I do something about it ?
Update:
The water comes from over head water tank in terrace
Update 2:
After cleaning the aerator , the sound stopped in the tap.
Please find below two AV clips: These below taps there's always a turbulent water flow .. I wonder some air bubble cause it . why ? this always happens , there are no aerators attached as well.
Please find the below AV clip: All the taps except above two has streamlined water flow.Please see the video of streamlined water flow.
King
  • 117
Sounds like it could be mineral build up in the faucet or water pipes that's restricting the flow of water causing vibrations and the whistling noise first try changing or examining the filter that's in the faucets exit valve where the water comes out at and see what kind of build up is there if any.
bugjr2
Looking at the water flow, there's no bubbles in it, even though the faucet appears to have an aerator. If you remove the aerator, does the whistle stop? I suspect the aerator is clogged or defective. Abnormalities in water flow make odd noises.
VWFeature
  • 311
