What equipment, tools and supplies do I need, in order to build and maintain a single fiber optic network connection between two buildings that are about 600 ft apart, separated by forest?
The way I am thinking about this problem is, instead of connecting an ethernet cable between two ethernet switches, I need to make a similar connection with a fiber optic cable. I'd like for it to be reliable for years. But I really don't know how to do it at all.
EDIT/UPDATE: thanks very much for all of the excellent replies. In just one day there's a huge wealth of information I was unable to find previously. I have incorporated some edits to clarify things that were unclear.
EDIT/UPDATE 2: In the interest of focus, I moved my question to the top. There are several clarifying questions below, which are not required to answer the main question, but give insight into my process so far and may be helpful components of the overall answer.
Note, I'm also considering alternate solutions -- see the below section on alternate solutions. I'm asking about fiber and other possibilities, so I can gather sufficient information to compare them to the other options-- including the pair of Ubiquiti Nanobeam 2.4G dishes that I'm running right now.
Some optional clarifying questions that have come up in my mind:
- Do I need a media converter on each side, or is there another option for connecting the cable on each side?
- Does it make sense to get a fiber optic cable of the correct length with connectors pre-installed?
- Alternately, could I buy cable and the tools and connectors, and install the connectors myself? If so, what tools and supplies would I need to do this?
- My initial research pointed me towards OM3, is this a good choice for my scenario? (more details below)
- I'm considering either getting some armored cable and running it across the forest floor, or getting some conduit, perhaps metal conduit or liquidtite, and then I probably don't need armored cable. Any recommendations on this topic? (more details below)
- It would be great to be able to patch a section of damaged cable if needed. Is this a practical thing to learn to do? What tools would I need? Is single-mode cable easier to patch?
- Where can I purchase the different tools, cable, connectors, media converters, etc.?
A few more details about my specific project:
This is for residential use, including working from home. The two buildings are actually a well pump house and my main house. The ISP service comes into the pump house - this is a small rural ISP - and I need to bring the service to my residence, which is a long way from the road and utility pole. The ISP charges $12.50/foot for trenching and fiber installation past 100 feet, so they installed their ONT just inside the property and I'm taking care of the remaining distance. I'm outside Seattle, so we don't get a lot of intense heat, but there's a lot of moisture for much of the year.
My ISP offers Gigabit speeds so it would be nice to install something faster than that, 10GB seems like a good way to be future proof. Although there are valid arguments against this so-called future proofing since 1GB is already way more than needed for almost anyone.
In the short-term, I'll be laying this down on the forest floor. Thus, it won't be a straight run, I'll need to go around trees and bushes, and sometimes pass it through thick brush.
(Several people have advised that laying cable down on the forest floor is a terrible idea, so I am reconsidering this. Although it is notable that a CAT6 cable has been laying on the forest floor here connecting a different building, and it still works after about 2 years; it appeared undamaged when I rerouted it a few months ago.)
Maybe in a year or two I'll be able to dig a shallow trench and bury conduit, but that's a much bigger project, and I need an easier short-term solution for now. I'll probably be using a flexible conduit to protect it -- recommendations welcome. Or maybe direct burial cable will be sufficiently strong and easier than dealing with conduit. Deer could step on it, but there isn't anything bigger than that around here. I'll probably route 2 cables on different paths so I have a backup / redundancy.
On another post I saw a recommendation for some single mode cable with steel wire protecting it, but it seemed that it didn't really bend in all 4 directions very well, which would be troublesome.
Someone suggested routing in existing conduit. The well pump has its own separate electrical service. For the home, the power company has an underground conduit that goes directly from the utility pole along the 700 foot driveway, not directly to the house but first to a utility owned box that remedies the voltage drop (at least I assume that's what it does.) I would not consider attempting to route anything in this existing conduit. There is also an old DSL line, a 3/8" cable in a 1/2" thin metal conduit. Maybe it's 7/16" cable, it's really tight in there. I am certain it would be impractical to attempt anything with this. There are no other conduits, unless you count the water line.
If I do bury conduit, on the one hand it might be easier to just go along the gravel driveway. However the driveway is narrow enough that we wouldn't be able to drive on it while the trenching is underway, which could be a considerable inconvenience. There just aren't easy answers here.
Alternate solutions:
- I have a wifi bridge working now -- that is, a pair of Ubiquiti 2.4G Nanobeam dishes. There is a risk of trees blocking the signal intermittently, especially in bad weather. I'm also unsure how it will perform in a rainstorm or the rare snowstorm. I will keep it as a backup. Cutting trees is not an option. No trees will be cut to create a better line of sight for wireless.
- Cat6a cable signal degrades after 300 feet or so. I have tested it at 500ft in a nearby location: it works sometimes, but is comparatively slow (60Mbps) and some networking hardware refuses to connect with it at all. (Google Nest router in particular would not make any connection.)
- Two or more Cat6a cables with PoE extender(s) in the middle would also be an option, and it's probably what I'll do if I can't figure out the fiber option. But the need for moisture protection makes this option tricky to execute. I'd like to be able to compare this option vs fiber, so that's why I'm asking about how the fiber option could be done.
Notable recommendations from answers:
- Someone recommended getting a switch with an SFP interface, rather than buying media converters.
- Someone asserted that the info about OM3 being cheaper or better is out of date, and that single mode is the way to go now.
- Someone suggested hanging the cable from trees in an aerial way, will consider!
- Someone suggested coax rather than fiber, so I'm adding to the list of possibilities that I need to research more.
Thanks for advice!
