28
In the winter, my house (~2500 sqft) becomes unbearably dry. Last winter, my wife and I used a tiny humidifier for the master bedroom to keep us from completely drying out, but since then I have been exploring a whole-house solution, complete with humidistat. It seems well within my ability to install it.
The trouble is, everywhere I've read that a whole house humidifier should not be needed. Normal humidity, they say, should be maintained simply by normal activity (showering, cooking, etc.). If the house is dry, it's far more likely to be that I have leaks (say, around my recessed lighting), and then adding a humidifier would risk mold issues.
So this is my dilemma: in order to find air leaks, everything I've read is that I'd need to have an HVAC guy come out with a blower door, which is very not DIY. So, expensive. Or, I could go boldly forth and just install the humidifier, in spite of the fact that I might not need it.
So, what should I do? Any guidance would be most helpful here.
Aarthi
  • 1,143
Nate
  • 782
6 Answers6
27
I went though a similar debate last year and ended up getting a whole house humidifier. I never remember reading that you should be able to get the humidity level to normal levels though normal means (shower, cooking, etc). In a big house, that is most likely not possible. Do you have a humidistat now, or does your stand alone unit give you a reading? I would recommend you getting one of those first to see how bad it truly is. If I remember correctly, if your humidity is below 30%, you could actually be causing harm to yourself and your home.
Our house approached 25%, which is dangerously low. Some of the driest deserts in the world don't get that low. For example, Las Vegas ranges from 21%-39%. You may be living in conditions that are way too dry.
All that being said, I knew we needed to do something. You mentioned worrying about mold, sure this could happen if you raise your humidity very high, but think about it, in the summer your home probably approaches 80%-90%. With humidity that hight, and the warm temperatures, that natural condition is more likely to produce mold than your 70 degree house in the winter. Plus, you will find just increasing your humidity to like 35%-40% with your whole house humidifier makes it very comfortable. AT that level, mold is unlikely an issue. The added bonus us that the more humid the house is, the warmer it feels. Again, just like in the summer, a humid 90 degrees is much warmer than a dry 90 degrees. We found we were able to decrease the temp of the house simply by adding a little humidity. Used to be 72 degrees at about 25-30% humidity, we now keep it at 70 and 35-40%. So we save heating costs there.
Ok, so what kind to buy? I researched the various types of whole house humidifiers, and it comes down to three types.
  1. Drum - These are the least expensive and easy to install. They install on your cold air return line, and use a motor and belt to essentially lift cold water from a drum into the the air and let evaporation and the passing air movement to pick up the moisture. These require considerable maintenance it has standing water and risk of mold due to the standing water. You have to replace the belt frequently. I opted to not get this one due to the standing water and maintenance issues.
  2. Flow Through - These can be installed on return or supply line. These are the middle of the road in cost and performance. Again, they also use evaporation, but you do not have standing water. There is a filter that water flows through (drip) and the air blows through the filter. The water however, needs to be drained, and new water is always trickling though. Since it always uses new water, the risk of mold is almost none. Uses no electricity, but does requires a water line and is always using new water.
  3. Mist / Steam - The most expensive, but most effective. They actually produce steam, rather than relying on evaporation. Because of this, you can more easily control the desired humidity. Can come in cold and hot water forms, injecting hot or cold steam into your supply line. Requires both electricity and a water supply line. Risk of mold is low due to no standing water, but the hot steam could cause issue in your ducts if you run it too often and too high I imagine.
I opted for the steam model, mainly because of the low maintenance and ability to control the desired humidity more easily. I installed it in an afternoon, it was easy to do. Most of them come with high end humidistat / thermostat, that would replace your existing house thermostat. Then the system knows how to control the furnace to optimize the output. I went with the Honeywell TrueSTEAM series and it has worked great. Good Luck!
Here are a few other descriptions:
http://www.just-humidifiers.com/works.php
http://www.guide4home.com/care-hf/whole-house.htm
Neil Miller
  • 103
mohlsen
  • 6,359
  • 39
  • 47
The blower door test is not too bad. I had an eco energy audit done, which includes a blower door test among some other visual inspections, and that was $150.
Fixing any leaks will help with your humidity, as well as help with your heating and overall make your house more comfortable.
I'm not sure if it will totally replace the need for a whole-house humidifier or not though, but it doesn't hurt (aside from the cost for the test, anyways).
gregmac
  • 29,300
  • 89
  • 162
The problem with adding humidity to a leaky home is amount of water vapor air can hold varies significantly with temperature.
While 30% relative humidity at 72°F seems dry and harmless in and of itself if you cool this same air to 38°F (let alone -10°F it sometimes get) all of the sudden you have reached 100% RH. The difficulty is making sure condensation of water vapor is not likely to occur within walls of your home where it would be difficult for anyone to notice accumulations of moisture.
Least insulated portion of homes are typically our windows and so first indication of too much humidity for outside conditions is condensation of water accumulating on windows however this is not always true. Modern double/triple pane windows offer more insulation and raise risks that air leaks/missing insulation insides of walls may become first condensing surface before meaningful condensation is noticed on windows.
As outside temperature drops so does amount of humidity your building can safely support! We live up north in a well insulated home with a humidifier. When things get really chilly we still have to accept some level of discomfort. Using the outdoor temp sensors/frost protection features of control electronics is a good way to mitigate risks associated with allowing too much humidity for conditions and associated risks of mold/rot problems.
Other risks come from water damage from equipment/maintenance failures. Saddle valves are garbage never use them. Have a line plumed if there is not one nearby. Turn off water supply when away and at end of heating season. If you have an evap humidifier buy several pads up front and make sure they get changed once a year. Leak alarms (harbor freight) are free insurance. Mount evap units on return side if possible so if there is a failure and water leaks it does not leak into the furnace blower motor and control board. If located in the attic consider potted plants instead of a humidifier.
No more bloody knuckles/noses is worth a lot around here and so no regrets with overall decision understanding it is a responsibility.
  • 20,909
  • 95
  • 135
disk eater
I am a licensed contractor, home inspector and certified energy auditor.
Energy audits using blower doors in conjunction with infrared is ideal for air leakage that leads to heat and humidity loss and increased energy costs. The whole house humidifiers can be very problematic and can shorten the usable life of your furnace.
I have been on countless home inspections where these units are abandoned in place while the return air plenum is corroding and the blower compartment is plagued with heavy rust. On the inspection I did today the blower compartment had black mold.
These units are not "install and go" as advertised. Just like a portable unit needs cleaning and maintenance these systems do as well. People generally don't do that maintenance and they lower the quality of air leading to more serious health issues while prematurely aging their furnace. Do your due diligence and read the manufacturer's maintenance schedule before considering this option.
If you seal your internal heat envelope with the correct vapor barrier levels your moisture levels can be maintained by normal living activities with the minimal assist needed by a portable unit.
  • 20,909
  • 95
  • 135
Dmg
  • 59
Another suggestion, which is unfortunately not DIY is a thermal imaging scan of your house. They basically take video of your house with an infrared camera and it captures heat loss as color variations. The cost is comparable to the blower test. Here is a link to a sample thermographic inspection.
This may be one of those times where DIY isn't the best approach for detecting the issue. FIXING the issue could definitely be a DIY approach (I.E. adding more insulation, caulking etc.) but in terms of actually detecting the problem, there are some specialized tools that professionals have that could really make the job of detection much easier.
I am just going to add my two cents answer here for what it is worth.
I am wondering what kind of Heating Unit you have ?
Is it a gas furnace , electric furnace - these units operate like ovens and to dry out the air - removing moisture.
Using a radiated heating system is better than buying a whole house humidifier for a condition that is caused by your heater, like taking a pill to manage the symptoms of taking a different pill.
There are in floor radiated heating systems as well as in the Air handler systems Aqua-Therm is one that uses the hot water heater to feed hot water through radiant pipes in the air handler. Using a Gas Hot water heater makes this a very good option as far as costs and also Humidity - while it heats the Air it does not dry it out like the oven style gas or electric furnace.
So rather than invest in a whole house humidifier - invest in upgrading something that you already have installed (a better heater ) more efficient and maintains humidity.
Just my two cents - I know these systems work very well - I had an Aqua-Therm unit in a house I was in and it was the cats meow..
Ken
  • 5,453
