I accidentally snapped off one of the hook latches on my microwave door - the door will shut, since the other latch is still there, but the safety mechanism of the oven prevents it from operating (since the second latch is not engaged).
Does anyone have suggestions on how to fix this without taking apart the microwave door (which I find intimidating)?
  • 20,909
  • 95
  • 135
Ken
I popped the inner seal on the door (facing inward) the latch had a spring that was detached because thplastic hook for it broke. I bent a wire and drilled a small hole in the latch piece and reattached the spring. If I didn’t have to figure it out, it would take 15 minutes. It took me an hour.
Tim
If you don't want to disassemble the door or replace it, then don't fix it. The dual-hook latch system is designed to ensure that the door is completely closed. Both hooks have matching sensors and both must be actuated for the oven to run. If you don't fix the door, then the only other option is defeating the sensors, which defeats a critical safety feature.
longneck
  • 21,448
  • 52
