We had a contractor come out to fix some drywall, flooring, and subfloors damaged from a plumbing leak. The floors had hardwood, which we installed over sheet linoleum. They removed both those layers and then a layer of what appears to be asbestos tiling underneath with no precautions other than loose plastic like you’d use for drywall dust. HVAC was on, nothing was sprayed down.
I am getting the tile tested. Is it safe to stay in the home in the meantime? Assuming it is positive, what abatement/remediation is appropriate? Thanks!
