Is it safe (from water intrusion perspective mostly) to reuse newish LP siding?
My project is to basically re-sheath, wrap and reside 3 walls. On the largest wall I pulled off this siding which was made either 5 mar 2023 or 3 may 2023. Either way it's pretty new. It looks like it's in fantastic condition.
I read this website https://coloradosidingrepair.com/blog/damaged-composite-wood-siding-needs-replacement/ which says to just replace the whole wall for"integrity", but that's for a damaged side. This siding isn't damaged.
Thanksshowing product label manufacture date
seeker
I see 2023 stamped on it, so yes, reuse it if its free of damage. If it was dated between 1985 to 1995, then I would do some additional research to verify that the particular product wasn't recalled by LP (they lost upwards of 1B USD in a class action lawsuit for a product manufactured between 1985 and 1995).
Looking at the website that you referenced, I can only speculate about what they intended by
Repair and Replacement Alternatives
Depending on the type, age and level of damage, a partial siding replacement may work to fix the issue. If the current siding is a better-quality, composite wood material like LP SmartSide, a partial replacement is an option. Though, this still usually requires the entire wall to be replaced in order to ensure the integrity of the replacement siding installation.
I suspect that they don't warranty partial replacement work like they do a full replacement.
popham
  • 10,617
