Sewer gas has been leaking into our main floor bathroom for the past couple of months. After several visits from our plumber with no success fixing the problem, he's told us he's stumped and doesn't know what else to do.
Here's what we've tried so far:
  • regularly run water down all the drains in the house, & made sure the p traps in the affected bathroom aren't dry or leaking
  • poured boiling water, baking soda & vinegar down the drain multiple times to deal with any biofilm
  • replaced the toilet wax seal and caulked around the toilet base
  • checked the soil stack is venting properly at the roof, and ran water down it to ID any leaks up the line from the bathroom - none we could see where the pipe is visible in the attic or from a cutaway in the bathroom wall
  • flushed the basement/foundation drain
  • vent missing on the plumbing under the sink, so we had one installed
After doing all this, the sewer gas smell has improved some, but is definitely still coming into the main floor bathroom, especially when we run the bathroom exhaust fan when the door or window is closed, or when the weather is warm.
Any suggestions for what we should try next? Smoke test/camera diagnostic to look for a leak somewhere down the line from the bathroom?
orchest
Make sure it's not a natural gas/propane leak. They can smell the same.
If you know how to relight pilot lights, turn off the home's gas supply and see if it dissipates.
user71659
  • 1,278
I know is an older post but we had the same problem with the smell leaking into the house, had an inspector come out to do a warranty inspection and just found the culprit our bathroom fan is tied into the sewer exhaust. Maybe this will help someone.
user231140
