I'm building a house (brick, cement and concrete) and I have a big pile of wood used for beam and pillar molds.
How can I properly clean cement off wood? I think it should be very damaging to blades in general (planer, table saw, etc), and sanding it out wouldn't be very effective.
  • 20,909
  • 95
  • 135
Luiz Borges
  • 2,345
  • 69
  • 83
You could try X'Crete which is advertized as suited to removing concrete from forms. It dissolves the concrete into a slush you can rinse away. There's probably other similar products.
Or a more hard-core approach would be to use Muriatic Acid; apparently that's what masons use to clean their stuff. Downside being it's dangerous.
A more tool-oriented approach would be a belt sander with a low grit paper. Belt sander don't care.
Bryce
  • 526
Knock it off with a chisel and a hammer, then plane it.
longneck
  • 21,448
  • 52
