I am remodeling a bathroom and have done demo down to bare studs. I am going to tile the bath tub (with shower) up to about 6 ft, and one wall will have tile up the wall 4 ft high. I am planning on using backer board behind the tile in the bath area, and as underlayment on the floor, but I am unsure of two things:
  • Should I run backer board behind tile that is on a normal wall? The wall with the toilet and vanity will have tile 4 ft high, but this won't be a wet area generally. Is greenrock acceptable here?
  • How do I transition from backer board to greenrock? Should the tile overlap onto the greenrock in the not-wet areas? And around the shower? Or should the backer stick out past the tile and get taped and bedded like sheetrock?
DMoore
  • 50,637
  • 93
  • 208
user15741
  • 306
Backer needs to go up at least 5 feet and extend a couple inches out a tub surround and used in all parts of a shower. It only needs to be in the wet areas.
For tub surrounds I normally put two horizontal pieces of backer board (goes 6 feet over tub top). Tubs are usually 5 feet in the US and backer is sold in 3x5 pieces. I then put one piece vertically on each side (going out a few inches) plus a partial piece to meet the 6 foot back wall. So I need to buy 5 pieces for a typical tub surround.
You meet your drywall from above and side from there. Just a normal join. I use mortar to fill backer to backer joins and drywall mud for back to drywall pieces. I really really suggest tiling over your backer to drywall joins too since 1/2" backer isn't as thick as 1/2" drywall. The tile coverage makes it easier and looks better. You don't need to backer behind your toilet or anything like that.
Edit - I would also note that I almost always have to add 2x4s to allow me to attach the side backer boards and allow for a firm place for drywall to meet. If everything in the room is "down" then I would actually put up 2x4 after backer - so I can make sure it meets in the middle with no cut. Cutting a 1/2 inch of backer board isn't worth the time!
Also I like a 2x4 right outside my tub external too - these are there a lot of time but not always. Obviously I would have to put this in pre-backer install. This is more for attaching your drywall.
DMoore
  • 50,637
  • 93
  • 208
