Short version:
-I am interested in hearing your thoughts on how best to install a cold-weather sillcock/hose bib & I am running into some MIP/MNPT uncertainty.
-Situation: I can find an adapter from our water line's PVC to MNPT (SharkBite model UIP120); the sillcocks I am finding are MIP (or Shark Bite).
-Problem: I cannot find a MNPT to MIP adapter (e.g., 1/2" FNPT x FIP)
Longer version: Our home, in the south, was not designed for freezing weather. However, a hard freeze is predicted this winter (following several years of freezing winter weather) and I would like to 'upgrade' our standard hose bibs (1/2" PVC line in our crawlspace to standard hose bib) to frost free/freeze resistant sillcocks.
The crawlspace is very tight and I would like to avoid dealing with PVC primer and cement (and the possibility of not being able to do a good job making sure an appropriate join is made in the very cramped space).
It seems I have two options:
Preferred option (1):
- 1/2" PVC water line
- Shark Bite 1/2" PVC x 1/2" MNPT
- metal adapter that I can't seem to find and maybe doesn't exist? (1/2" FNPT x FIP)
- MIP sillcock
Alternate option (2):
- Shark Bite 1/2" PVC x 1/2" CPVC/PEX
- ~4 inches run of 1/2" CPVC/PEX
- Shark Bite 1/2 in. Push-to-Connect x 3/4 in. MHT x 12 in. Brass Anti-Siphon Frost Free Sillcock Valve
Question: -Am I missing something with regard to transitioning from MNPT to MIP? -I see in some places that people directly thread a MNPT fitting to FIP. (This makes me a bit nervous since the location is not readily accessible/able to be monitored) -Is there another, easier, option I have neglected?
TL;DR: all the water lines in the house are either 1" or 1/2" Charlotte Pipe PVC 1120 SCH 80. I am working with the understanding that MNPT/FNPT (male/female) National Pipe Thread is not directly compatible with Male/Female Iron Pipe given that one is tapered and the other is straight.
