I just purchased a 11'x23'x8' aluminum pergola from Wayfair that will arrive in a couple weeks. It weighs roughly 750lb. In some reviews, it says the concrete screws that come in the kit are kind of weak so I'm looking at beefing them up a bit.
The pergola has 6 posts and each post has 4 pre-drilled holes on baseplate. The predrilled screw holes are about 5" apart. Research tells me I should have at least 10x distance of fastener diameter between holes so 3/8" sounds like the widest I can go. I plan to get a rotary hammer and drill some of the holes 5" from concrete edges.
I have a concrete slab that is 4" thick. No footers. Been searching the internet for past few hours trying to find proper guidance on recommended drill depth and cant seem to find anything.
There are a total of 24 concrete anchors/screws to support the 750lb pergola. I live in md and we do get gusts up to 45-50mph. I'm leaning towards Tapcon+ 3/8" diameter concrete screws to not put too much outward pressure near concrete ends(I hear wedge anchors do this).
Now after providing backstory and details of my project, here are my big question I'm hoping someone can help with...
What is the recommended depth to drill into my 4" slab? (For 3/8" fastener)? I was thinking drilling a 3 1/4" hole and using these 3" Tapcons.
Or should I go with the 2.25" depth fastener and drill only 2.5" into the slab?
I know there is reinforcement near center of slab, (chicken wire and some rebar) so some spots my not be able to go deeper than others.
