I'm about to move into a new construction house and i need to get a fiber cable run from my pantry/mud room area to my living room. Server rack will be in the pantry and control box will be in living room (using a Icron Raven 3124 to connect them) I already have the dock and have been using it very successfully and want to keep using it to keep sound and heat out of the living room. Also i will be installing 7.2 surround sound and will need to get wires from the receiver out to the ceiling mount front and rear surround units.
I've done this exact work before but it has always been in a single story house so i can easily go in the attic string it across and poke a couple small holes and the speaker is right there in the corner covering the tiny hole, or run it down inside the wall and put a brushed wall plate and run everything through it.
Problem is i now have a 2 story house for the first time and there are bedrooms above my living room so i cant just go in the attic to do things like before. I have a crawlspace so i was thinking i could run the fiber cable down through that. Like punch a hole in the wall and put a wall plate and then drill a hole in the wood from the bottom and fish the wire through and do the same in the living room wall but the living room wall in question is an outside facing wall so it will have insulation which I've conveniently never had to deal with when running wires in the past.. But i dono how to smoothly get the speaker wires out and about or if there is a better way to do the fiber cable either. Any help would be much appreciated.
