I have very low hot water flow (0.7 GPM) to my master shower. Other fixtures served by the same hot water line get about 2.5 GPM hot water or more.
I suspect that there is a kink in the final PEX run to the shower, but want to eliminate the possibility that the thermostatic valve in the shower is malfunctioning and restricting the flow before I start cutting into drywall to find the restriction.
Here are the clues I have gathered so far:
- Shower hot water flow is the same 0.7 GPM before and after the water in the supply line has heated up.
- Shower cold water flows fine.
- I am turning the temperature control all the way up past the safety detent when measuring hot water flow.
- In the summer, our showers are great. I attribute this to the fact that the cold water supply comes in at 85F or hotter (I live in Texas), so the trickle of hot water is enough to give a comfy shower.
- In the winter, the shower is unusably cold. I presume that is because the cold water is coming in at closer to 40F, there just isn't enough hot water volume to balance it out.
- This shower system was installed in early 2022, and we don't have particularly hard water where we live.
- Our previous shower system had a thermostatic valve that was broken and couldn't adjust the temperature. With that old broken valve, we had good showers in the summer, cold showers in the winter.
- The PEX line was run by the previous homeowner, who was not living in the house at the time, did a DIY remodel of the whole upper floor (where the problematic master shower lives) in a hurry to sell, and was (according to neighbors) a certified weirdo. I can very, very easily believe that he just didn't feel like going down the street to Lowes to get the correct coupler and bent the PEX more than he should have.
I'd like to avoid the cost of testing out a new cartridge (or thermostatic valve or whatever) if these signs point clearly to a restriction in the supply. I'm not even sure I could find a replacement cartridge for my shower system, honestly.
Is this enough information to start ripping into drywall to examine the supply line to the shower? If not, are there any other experiments I could do to narrow it down to restricted supply (or alternately, confirm a faulty valve)?
(note: I posted a related, but rather less-informed question about this problematic shower a couple months ago - now that it's getting colder, I can confidently say that the capacity of my tankless water heater is not the problem based on the amount of hot water I get at other fixtures)
