I want two two post lifts, one 80 gallon compressor, 15,000 watt heater and outlets for normal use and lights.
What size breaker box do I need and what gauge wire do I need if is 80 to 100 feet away from my main panel?
Supu
The usual conversation here is someone wants a 6000 watt electric heater and we kind of nudge them in the direction of a heat pump because it'll be a big cost savings over the life of the unit. But I know the heat pump will cost more to buy and install than the space heater, so I don't get my hopes up.
Your situation is completely different.
A 15,000 watt heater will need 80 amps of power provisioned to it. Eighty amps.
It's a hard HVAC load, which means it'll come in at 100% on your NEC 220.82 Service Load Calculation. There is no way you're talking your way out of a service upgrade on this one, unless you "do the impossible" with an energy management system. Either way, provisioning this will cost a fortune. And on top of it, when it's all in, you'll be paying $2 per hour (in 2019 prices) to run the thing. And it won't give you air conditioning; you'll have to spend again to buy that. And an air conditioner is a heat pump, so you're buying a heat pump after all, just a crappy one without a reversing valve.
No, this is not financially rational. It won't even give you
A 15,000 watt heater will come in at about 50,000 BTU. So that's a Williams/Empire double sided wall furnace. That run on propane would be slightly cheaper than electricity right now, and 1/3 the cost on natural gas right now.
But if you want cheaper operating cost than natural gas, and air conditioning as part of the deal, all the wind's blowing toward heat pumps. "I'm in Chicago" so is Alec from Technology Connections, and did a case study on the hellish 2019 Chicago winter in video 2 of this series. The Asian style heat pumps are sensibly priced and have no trouble with the cold. To get the BTUs, I would put in 3 cheap ones, rather than one large "heat pump to rule them all".
