I recently got some contractors over to repair a section of my house and they unknowingly spilt a small amount of acid on my marble floor.
They did not attend to it immediately and the acid corroded the surface of the marble floor.
How do I repair it?
  • 20,909
  • 95
  • 135
Japster
You would normally clean marble with etch spots with hydrogen peroxide or bleach and then repolish. From the sound of it yours may be more severely damaged. I would try both on a small spot and see how it goes.
If your marble is actually corroded then you will have to polish until you hit uncorroded marble.
DMoore
  • 50,637
  • 93
  • 208
Corrosion of marble (a form of metamorphic limestone) is not a stain, but rather a dissolving of the base rock.
The solution (if not too deep) might involve surface grinding, honing and polishing in place, but is not a DIY project. Discuss with a marble installer/fabricator.
Another solution (if the marble tile is available) is to replace the one tile.
HerrBag
  • 12,225
  • 37
