I am installing a 27K BTU Mr Cool min split (install guide) that requires a disconnect/shutoff.
I want to make sure I am correctly wiring the disconnect, as I cannot find a wiring diagram for it and there are not good instructions with it. Here is the model I am using: https://www.homedepot.com/p/Square-D-QO-60-Amp-240-Volt-7-4-kW-Non-Fuse-AC-Disconnect-QO200TRCP-QO200TRCP/202353314.
Here is how I have it wired, followed by it with the shutoff, but no mini split whip installed yet.
- Am I sort of an idiot (or at least wasting time & money) and I do not need the neutral?
- I am assuming I will just wire the mini split whip to the shutoff switch in the second picture?
