I have a smart light bulb that needs constant power connected in order to be controlled via my smart home. However, I want my guests to be able to control the light via a switch as well.
I bought a small Sonoff switch that requires no neutral to work, since I do not have neutral in my switch wall boxes.
What I’m thinking is that I can let the light bypass the switch and connect the switch to the Sonoff smart switch, and then using automations, control the light whenever the physical or sonoff switch is triggered.
However, I wanted to verify if the circuit I’m thinking of wiring up is safe to use. The sonoff needs no neutral wire but requires power (Line) in both its Lin and Lout to allow a small amount of current to leak in order for it to power itself.
Will I create a sort circuit by bridging two Line cables together and is this dangerous? Will the sonoff switch work, or the current will just bypass it since there is a path with less resistance? And finally, is this connection safe to do?
