I'm converting my attached garage to a living space. The floor is graded and so will need to be raised (likely via putting an osb subfloor on top of it).
Current garage slab has contraction joints cut in the middle, and a fiber filled expansion joint around the outer edge.
Is there anything special I need to do to seal, fill, cover, etc, these joints, before they are permanently covered with new flooring? Or just leave them as is?
My gut tells me they need to be left as is, since their function is critical to protecting the slab, but just want to make sure there isn't some preemptive measure I need to take before they become difficult (albeit not impossible) to access.
